Discuss Mains and UPS disconection in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone,
here I have some problem with schematics (schematic attached). The SK_2 is circuit for disconecting main lines and UPS. So, I guess that S2 is a muschroom on switchboard's door, which will disconnect the Q1 circuit breaker. But, what should be K1 (24VDC). Is this relay used for UPS disconnection? How is this connected?
S2 is a 'latching mushroom, turn to release' pushbutton. It shows no wires going to it. K1 also shows no wired going to it.
There also doesn't seem to be a shunt trip for Q1 so I don't know how S1 will disconnect Q1.
Its hard to understand the pic of the schematic.
Is there a K1 contact anywhere in the sheets?
I suppose that this K1 is supplied via AC/DC converter and if we press the mushroom we will disconnect Q1 via shunt release and because AC/DC converter will stay without voltage the contact of K1 relay will change NO/NC state and sent signal to UPS, and finaly disconnect UPS. So, with muschroom, UPS and mains will be disconnected. But, I'm not sure. Does anyone have some other idea?
Reply to Mains and UPS disconection in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, friends. How can we understand whether the windings of the transformers we use in spot welding applications are intact? The...
Hi all, I have been on a site repairing damage caused by travellers collecting copper for the last week. We have found and replaced cabling to get...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
Good afternoon! I've recently wired a lighting system, where one light switch (a motion sensor) turns on two lights, but another motion sensor...
