G
Guest77
Run a 16mm down there and fit a board FFS
Discuss Massive run!! in the UK Electrical Forum area at ElectriciansForums.net
The bride might get cold feet?It will be in writing. And labeled at the end of the cable run. And noted on the certificate and everywhere else I can put it. Can anyone see any problems other than that?
Don't rub your spurs on the wallpaper when you walk through the house.I've been told lights. I'm not going to put anything other than 6 amps down there
If they have that much money get the dno to quote for its own supply then that way they can.have what they want down there. Had the same sort of problem few years ago with a stable started of with just one light and one socket ended up the stable became stables snd a summer house office so lot more required than original quote.Run about same as yours.
Reply to Massive run!! in the UK Electrical Forum area at ElectriciansForums.net
