E
elliottjon
can anyone tell me if it matters which way round an MCB should be connected (mains in to top or bottom) in my case the MCB is 3 phase?
The MCB has a drawing on it indicating a supply side and a load side that would count as manufacturers instructions which should always be followed. The MCB will trip if overloaded either way . Intrigued as to how this question has arisen?
thanks for your quick responce i'm replacing a faulty mcb and the and enclosure, the cables are now not long enough to go in the same way, supplying another board
Can you not replace the MCB like for like? Is the new enclosure not a Dis Board with a bus bar. I'm confused as to the set up you're trying to achieve.
I can't see how putting a Mcb in upside down will make it bigger, so as to fit shorter cables. Use a rccbo they are much longer and with give better protection to boot.
