Hello,
2008 c200 W204. I have been having trouble for ages. Advice seems to be: change the stalk assembly, but not convinced that is the answer.
Intermittent problems, this is the latest manifestation. No wiper action or washer action on any of the positions, switch ignition on an off and all functions return for a period of no fixed duration, sometimes days sometimes half an hour.
Occasional problem with indicators, same solution and result.
Surely this cannot be the switch, as it seems dependent upon ignition on-off cycle.
Any advice gratefully received.
JohnT
I suspect a bad earth common to wiper and indicator assemblies.
When the fault is present do you get 12V at both sides of the wiper fuse?
Stoke on Trent
Business Name
None - Private individual
Mercedes W204 Indicator/Wiper switch problem
Auto Electrician Forum
Thread Tags
electrajohnt,
DPG,
