Discuss Mercedes W204 Indicator/Wiper switch problem in the Auto Electrician Forum area at ElectriciansForums.net
Hello,
2008 c200 W204. I have been having trouble for ages. Advice seems to be: change the stalk assembly, but not convinced that is the answer.
Intermittent problems, this is the latest manifestation. No wiper action or washer action on any of the positions, switch ignition on an off and all functions return for a period of no fixed duration, sometimes days sometimes half an hour.
Occasional problem with indicators, same solution and result.
Surely this cannot be the switch, as it seems dependent upon ignition on-off cycle.
Any advice gratefully received.
JohnT
I suspect a bad earth common to wiper and indicator assemblies.
When the fault is present do you get 12V at both sides of the wiper fuse?
Reply to Mercedes W204 Indicator/Wiper switch problem in the Auto Electrician Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hello I have a central heating system, with a Y plan layout. The neon indicator on the thermostat seems to be sometimes dimly lit / flickering...
I posted back in April about a wierd starting issue but unfortunately got no replies and the issue is still ongoing and driving me nuts ! I have...
Hi I don’t know how resolve this so any helpful advice would be greatly appreciated. I have no electrical knowledge. I will try to be as clear...
11K
