B
badwolf
Can I get the dno to move their equipment as it is too close to the incoming gas supply, presumably the gas supply came in later, but now poses a problem! Or can I get them to change their service head, as where the incoming cable comes in is cast with the fuse inside the metal container, I've not seen this type before, does it need replacing?
Thump it with a hammer to crack it, then artistically puff some soot into the crack to make it look like its come from inside, then phone up the DNO and tell them you can smell burning and the metal is hot to the touch. Instant replacement. :)
Disclaimer: whilst delibrately vandalising DNO property is fun, it is generally frowned upon and may result in disapproving looks, prosecution, death, or an afternoon with the mother-in-law, so is not recommended.
