La Poste
- Reaction score
- 126
Greetings.
I've got a friend who lives in Thailand in a house with no earthing.
It's a two wire system with a RCD/ELCB at the point of entry to the house.
They seem to do this in Thailand, put an RCD at the main incomer even though they have no earth circuit.
I guess something is better than nothing and the logic is if there is an earth fault to the frame of an electric heater for instance and you then touch
the frame of the electric heater and get an electric shock the main RCD will switch off the supply as long as more than 30ma flows through you to earth.
My friend is getting electric shocks off of his computer equipment, the metal frame of his PC.
Without going into the earthing system of the whole house would it be safe just to earth the PC chassis by means of an earth rod without involving anything else in the house?
I'm thinking if just the PC is earthed with a local rod this should take care of any leakage current that is building up.
My friend has no test equipment and we don't know anything about the local transformer or whether the transformer is earthed itself.
Is this a safe thing to do and what would you recommend in these circumstances?
Thanks.
Thanks.
