Mar 2, 2024
Uk
Hi all, have an issue with our Mira platinum dual shower, the water flow stopped last week whilst in use and the wireless control unit showed the out of range symbol.
Have tried resetting, reconnecting and power cycling but the control unit is still out of range. Have had a plumber out who has advised that the glass fuse in the mixer unit is popping but could not tell me which part is faulty (pump motor, etc). Any ideas?
I suspect the reason you haven't received responses here is that it's difficult to give a meaningful answer.
Since the internal fuse has blown, the controller and receiver probably don't have power, and hence the remote can't get any response, confirmed by communication failure message.
From your post wording "the fuse is popping" I infer the plumber replaced it, but it blew again?
Without an internal wiring/ circuit diagram, and appropriate test equipment, it's difficult to divine what's wrong.
I feel the most realistic solution is to grit one's teeth and ask Mira for a fixed price repair at £350! If you try to DIY repair on the basis of changing things that might be 'the fault', you could end up spending a lot and still not fixing it.
Thanks for the reply, yes the plumber replaced the fuse and it blew again.
Replacing the pump, or the PCB is circa £250 each so it looks like the Mira fixed price might be the right option
Reactions: Avo Mk8
Uk
Mira Platinum Dual Shower
DIY Electrical Advice
Thread Tags
PADGET5783,
PADGET5783,
