FuseBox SPD1MT2 are direct to busbar with no mcb i used one recently.I’m not sure of MK, but every other make of SPD has had an mcb before it in the boards.
The new Proteus from CEF are making a big deal that their SPDs have an internal fuse, which frees up a way in the board.
It might be interesting to see if other brands offering the same kA surge protection have the same size mcb up front (from memory, 32A)
Ideally I would try to rate the MCB as high as I could, but would still allow selectivity with the main cutout fuse should the SPD fail short circuit. Alternatively, I'd have thought a 32A MCB would be fine, which seems to be the standard for SPDs in CU's.But what rating?
I'd say it is as easy to spot as all of the other characteristics on that data sheet.Brother Blue pointed out that there is a reference to a requirement for external protection - but I have to say it is not easy to spot.
How is that not definitive? It is a definite maximum rating, you work within that and establish what is appropriate for your installation. Pretty much every installation is going to be different in it's characteristics and requirements.Bother Blue, I do take your point that the maximum should be 125A, so, again, not definitive.
Ah, a TT earthing arrangement, there is something else we also need to consider here.Thanks Avo Mk8, that was an interesting vid, it's partly a sales pitch, but does have relevant insights. Thanks also to littlespark, mickegh and mainline for your suggestions of alternative brands to consider. Pretty Mouth, the earthing arrangement is TT and your thinking that 32A should be about right corresponds with the various retailers I've asked about this; they've suggested the same but without any certainty. On balance I might try for the Fusebox single module or the Wylex one. Thanks to all.
Yes for that SPD .. Is it the same model as above queryIf you buy an MK populated Consumer Unit the SPD is connected directly to the Main Switch. Does this not indicate that this is how the Manufacturer intends it to be used, i.e. no MCB.
