Dalf
Hi
Could anyone recommend some nice modern lighting for a house refurb.
I'm aware off jcc led downlights but anyone recommend any others that look modern and bright?
if you want modern lighting, go for these new fangled electric thingies. you don't want to be left behind fitting oil and gas lamps.:sunny:
Haha and there was me thinking it was all about oil fittings.
Thanks for the thumbs up though I have just paged through the info to the client
aurora is a good source for downlighters. also there's some good deals from ebay sellers if you pick a reputable seller.
I've used qvsdirect.com in the past, for fire rated GU10 downlights. You can't then use LED lamps in them. 4W cool white lamps look the part.
I have used ledlite down lighters, they only seem available from TLC. Used them on a 3 separate jobs and all customers were happy! IP66 and fire rated. Maybe a little expensive, especially if you want anything other than white, you have to pay extra for bezels.
There are several verities are available in a market for modern lighting. If you want modern lighting in your house so you may use the following modern lighting solutions.
* OCO lights.
* Platonic suns lamp.
* Trex lamp.
* Raindrop chandelier.
* Babelute Lamp.
These all solution are easily available in market. Hope it will help you.
