Monitoring 3P meter import/export wirelessly
Hi Guys; can anyone suggest a way that I can monitor the import and export data from a three phase meter without using a cellular connection? The area where the meter is installed has virtually non-existent mobile coverage; can I use the pulsed output in some way, married to Wi-Fi? Any advice would be very much appreciated!
Meshtastic might be an option?
Thank you for the reply, but for the ignorant among us (i.e. me!🤣), could you expand on that a bit please?
Meshtastic is a decentralized wireless off grid mesh networking LoRa protocol. It operates at broadcast power levels which do not require a license to use. It is designed around exchanging text messages and data in off-grid environments, with potential applications in IoT projects where a decentralized communication system is needed without existing infrastructure
Many thanks for the further info, and this is something I'll definitely investigate.
Forgot to add yes you can measure the pulse from the meter to calculate energy usage.
All you need is something like a Raspberry PI or a Pico hooked up to a photo resistor. With a simple program you can measure the pulses emitted.
