G
glasgospark
most common causes for rcds to trip when main DB upgraded ?
appliances , borrowed neutral , fault elements ??
any more less obvious ??
Cumulative leakage.
Do you have a problem?
EDIT: Obviously this isn't real as no one installs boards with single RCD's any more DO THEY?
is this a round about way of saying you have a fault , cant work it out , and now need our help ?
1. Appliances with high protective conductor currents by design e.g. mains filtering.
2. Capacitive discharge currents? Dunno about this one but always wondered about it as a theory.
3. Someone testing Zs on the wrong setting, e.g. the pixies that live in the electrified garden shed.
4. Someone getting an electric shock.
I seem to keep finding small mk sockets with an odd design where the earth is in the middle. So again a N-E fault. Normally found in the back of a cupboard with a fridge attached too.
