B
bazza.a
Hi all,
first post here so hope this is ok, started 2330 in sept, (going great) we test our practicals for continuity, insulation resistance and polarity. The trouble is there's 20 in the class and 2 multi-function testers, can I use a cheap multimeter for insulation resistance on my boards such as this
[ame=http://www.amazon.co.uk/Draper-60792-Digital-Multimeter-Backlight/dp/B0001K9XKW]Draper 60792 Digital Multimeter With Backlight: Amazon.co.uk: DIY & Tools[/ame]
it does go up to 20megohms, i'm not looking for anything other than college work untill I complete 2391, it's basically to skip the hour wait for a tester, I did search this forum but couldn.t find the answer. I have a fluke t5/600 which does continuity tests, I'm also pretty skint any help or advice would be useful
thanks in advance
Barry :rolleyes:
Definately not. You have a multimeter which will not do the IR test, You will just have to be patient and wait your turn. Watch and learn as the other lads do their testing and do not be afraid to ask questions. Insulation Resistance/ Continuity or Multifuncton Testers are not cheap and I would not buy one at this stage of your studies, as it will only get used once a week at college if you are lucky.
and welcom to the forums
bazza.a,
bazza.a,
