Discuss Muppet Friday....... in the UK Electrical Forum area at ElectriciansForums.net
Dave Appleby
Ok.
I finally expect a roasting here.
So I finally decided about 6 months ago I needed a tube carrier.
Brought and fitted a 3m Rhino.
Ohhh... Shiny says Dave...
So I popped everything long in plus some shorter off cuts and ... Wait for it.... My spirit levels...
So my question is, how do I get them out without removing the carrier from the roof?
The James Herriott method has mearly resulted in lost skin and an attempt to cut my own wrist. Aluminium is now claret stained.
Really really open to suggestions. Although.... Leaving the back of the carrier open, reversing fast and braking really hard may not be an option.
Thanks.
Dave
Doesn’t your pipe carrier have a little door at both ends? Open them both up and push it out from other end….
Or
Is the spirit levels metal? Go fishing with a magnet on the end of a long stick….
Or
Long piece of wood with a nail half hammered in to make a hook
Or
Get a friendly neighbourhood crane operator to pick your van up by the front, tipping it until vertical… all the bits fall out.
*The last suggestion may or may not be serious. No liability accepted by the author of this post
tie a few feet of 1.0mm single cable to levels and trap end of cable under rear door lip.
Actually I did something similar only with me it was a conduit bending spring that ended up stuck in the middle.
I had some 10mm cable so made the end into a hook.
Reply to Muppet Friday....... in the UK Electrical Forum area at ElectriciansForums.net
I never did like transformer theory in my degree course and that was 40 years ago. I'm a boat builder now and we tend to have big battery banks...
The bit where I cut to the chase is in bold below if you can't be bothered with the back story. Changing MCB in main house DB for garage supply...
4K
I've just started an apprenticeship with a decent sized firm (I got taken on full time - hooray!) and was thinking this week about how a lot of...
13K
Hi, Before I begin my tale of woe, I have my tin hat ready! I'm retired from the trade, I started out just as the 16th came in and had a rather...
4K
Good morning , My name is Martin and I hope someone can help. I am planning to install domestic roller shutter onto our home. At first , I was...
