I use a KT61 Multi function tester - will be doing all the tests (blood, urine, hair loss and smelly feet) - hope that meets with your approval
clearly not up to your standard - sorry to disappoint you - inexperianced electrician - but hey we can't all be briliant can we
Hi ashrow - got your message but it wouldn't let me pm back until i had reached a number of posts.
In that case put live to earth and turn the mcb on. Iv only made 1 post but I suspect that if I required help with something i wouldnt be nowhere near as rude as u. Guess it comes with ur heritage tho so gl and use my advice. That is all
My approval or not doesn't really matter, I only ask because almost daily i come across installations where the only test carried out is switching on!! A guy I grew up with was electrocuted in his garden 3 years ago, the devastation to his family, obvious to all at his funeral, brings a big reality check to the danger of electricity.
Robert my man you will see that I was not rude to those who did help - I come from west yorkshire - oh near you - says something about you - you know the bit about my heritage - mup
By the way there is nothing wrong with the scottish
Thanks for your concern - I try to be safe in all that I do - I really am just inexperianced - my brother was killed by taking chances - hopefully thats one lesson I have learnt - even if I don't know how to wire a light to a sensor
well, the pir may be damaged when you carry out the insulation test, probably better to link the pir out of the circuit and test first, connect it afterwards.
White is functional switch wire so connect this to your brown from your lamp, the pir is just a glorified switch, as said above
and make sure the pir is sited where its not 'looking' at a source of heat...boiler flu etc...
michael0766,
michael0766,
