E
Ewol
First off. I have to apologize for posting here. I'm not an electrician, but I'm worried that my bathroom might be unsafe.
I turned the light on in the bathroom the other night. It made a 'bang' sound is all I can describe it as. I thought the bulb had exploded, but that was not the case instead it's hanging by the wires and there is a couple of burn marks on my bathtub. It tripped the fuse switch and if I try and switch it back on the house alarm goes off. ( I didn't even know it worked)
I took a picture. The light is above the bathtub.
Basically I just want to know if I'll get electrocuted if I take shower/bath.
Again, sorry and thank you for your time.
By the look of it the problem is with the light bulb and possibly nothing else although I couldn't guarantee that. With the power off you could very carefully try to remove what's left of the light bulb and replace it.
I can't help noticing the fitting is very close to the bathtub; if it's within these zones:
the light fitting should be rated to at least IP44.
Presumably your alarm is on the lighting circuit which you turned off; I'd guess it needs to be reset with the code to shut it up, although I'm no expert on the matter. Someone else might be along in a minute to advise on that...
your alarm is wired into the same circuit as the lights by the sound off things..... looking at the pic, your energy saving bulb has failed, come apart. 1st, Make SURE you turn the power to lights off in fuse board, once you do this check the rest of the room lights are off, now get a torch and take that blown lamp ( bulb) out, replace and turn lights back on, puch in alarm code, press reset or enter and you shoud be fine.
Unfortunately, I don't have the alarm code. That's something I'm going to have to contact the landlord about.
I think the fuse for the upstairs lights is already off. Does it do it automatically? Because every light did go out upstairs. It's when I try and turn it back on (Well, what I'm assuming is on) the alarm goes off.
So at the very least if I remove the bulb and what's left of it, it will be safe to at least have a shower?
You know what else is strange though. Every bulb in the dining room blew. I don't know if it's when I messed with the fuse switch and the alarm went off. Maybe I did touch the wrong one?
Thanks for taking the time to reply to my post, it is appreciated.
There's way too many variables here to be sure, but blown lamps on different circuits, alarm panels doing odd things....you MIGHT have had a power surge issue.
The IP rating of that lamp and lamp holder really isn't suitable for being just above the shower.
Get your landlord to replace it with a suitably rated (IPX4) fitting.
ewol, which area of manchester? if it's on the west/south west, it's not too far for me to call and sort it out for you. i can fix the alarm as well. i would ask you to pm me, but you need more posts before doing so. i'll pm you my email if you can receive pm's.
If the failed lamp is still dangling by its wires as shown in the picture, where did the burn marks on the bath come from?
Dont over complicate the issue.
Its a lamp that has failed simple as that, nothing more.
all you need to do is turn ALL power off at the consumer unit, yes I did say all.
Remove old lamp stub then insert new lamp. I would suggest using pliers as the stubs can be sharp.
turn power on. Hey presto job done!
With regards to the alarm. Depends on make of alarm, they sometimes revert back to manufacturers default.
PM and I'll try and help with code
I don't have a picture of the burn marks, there was only 3 that I could see. Very small.
Would love a shower or even a bath. Heh.
If I turn all power off, the alarm could still go off? I'm not sure I want to risk being unable to turn it off. If that's the only safe way to remove lamp stub, I might have to leave it until my dad gets back from holiday on the 2nd.
I was wondering about that - it would help explain why the lamp in the bathroom blew apart.
