Discuss NEMA 12 Enclosure from Saginaw in the UK Electrical Forum area at ElectriciansForums.net
If the specification to which you are installing specifies a NEMA 12 enclosure then I would suggest that you raise the point that they are not designed for outdoor use, even though they meet the IP rating for outdoor use, and so they may not have sufficient longevity for the installed location.
If you have done this then you are covered for any future problems.
Reply to NEMA 12 Enclosure from Saginaw in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi people, I'm having a brain fart moment. What is the minimum distance between enclosures, with doors that are facing each other? In...
4K
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
