Just looked at a job to replace an old re-wire able four way box. Quick test revealed good Ze and IR spot on. Only one problem, the b&q 10 way customer bought box will amazingly not fit into the small cupboard alongside the main intake, meter, and existing fusebox.
The meter tails can be moved, but I would have to extend the cables to accommodate the new fusebox.
My question is, would it be o k to crimp the cables to extend them, if so how would you go about covering all the connections to tidy them up?
Thanks in advance!
I'm sure you could crimp and extend but I'd go with uninsulated ferrules and heatshrink sleeving. Maybe some kind of adaptable box could house the crimps, a photo of the existing arrangement would be nice if you have one.
better still, use a smaller CU with a main switch and RCBOs. a 6 way board should do to replace the old 4 way.
