I've just had a new garden room done with electrics supplied via armoured from main house supply. Due to lack of space in the CU the electrician has put a mini CU in beside it (we now have three CUs as there's also one previously added for an EV charger). Garden room has its own 4 way CU for lights, sockets (incl external sockets), external lights, and air con.
The electrician tells me all this work does not require certification; is this correct?
As a second, lesser question, there is one 3 way light switch for the internal and external lights, it's a metal faceplate, with a terminal for an earth on it, however there is no earth cable attached, or run to the backbox; should there be? All the sockets appear to be earthed, as is the mini CU in the house, just this one light switch is without earth.
