M
matthewgordon
Hi all,
Do you need to be in the NIC or equivalent to carry out electrical work on domestic properties? Ive been told yes and no so many times my head is in a spin.
Ive read a part p fact sheet recently which says that if the work carried out isn't to building regs then you could be fined. So if it is to regs then that's ok?
What confuses me is that so many people I come across aren't with NIC and are carrying out work. They have quals including 2391 and produce certs for the clients.
I understand that some work must be nnotified to labc but let's say it isn't, and the work is to regs, what will actually happen? Does this just mean the client might need to get a cert done before selling their house?
Can someone give me the correct stance on this please?
Thanksin aadvance
As far as I understand it... And I don't is... You must be registered with a scheme to carry out any work that comes under part p, or you must notify your local building council thing. If the work doesn't come under part p, so long as your competent then crack on, just issue certificates for it. Issue a certificate for any work you do ideally then you have a paper trail and proof you stuck to the regs... Like I said though I don't have a clue!
Notification of works is a legal requirement, simple as that. Anyone doing notifiable work and not notifying are leaving themselves open to legal issues. In reality, nothing bad is likely to happen, but I couldn't sleep at night knowing I'd not complied with the law.
Join Elecsa, pay your fees.
If you aren't registered and do CU changes, you will find paying LABC will be about 1/3 to 1/2 of you fees!
a legal responsibilty of the homeowner , not the installer.
and as most LA's now accept third party certification and the list of notifiable jobs being reduced to basically 3 items , you may as well accept its become a free for all.
and...
yet again we have the never ending story....including `stars` such as the NIC, Elecsa and Napit...
but this is B list stuff...
as you dont need to be in any of these scams to carry out works....
its the LABC that needs to be notified of any...well, notifyable works that have been carried out....
further more its the property owner/customer responsibility to ensure notifyable work is notified to the relevent bodies..
and this is already getting dull now so>...........
BUT you would be deceitful IF you didn't inform the client of the Part P requirement.
Hello Matthew,
I think lots of electricians/Domestic Installers are a bit unsure about this!
My understanding is that if you want to undertake any work that is notifiable (i.e adding a new circuit to CU, replacing a CU or any work in a special location) then you do HAVE to belong to one of the schemes OR be competent to carry out the work and pay the £180 to building authorities to check the work.
If the work is not notifiable (i.e pretty much everything outside the 3 things in brackets above) then I dont think you have to be a member of a scheme but you do have to be competent and also offer the correct certificate.
It does seem to be a bit of a grey area, what is competent? I guess showing that you are able to do the work to the current regs!
Hello Matthew,
no...
yes...
no, no and no again..
go get competant will you Hippy caus some times for christs sake...
I am staggered that so many electricians don't understand the Part P situation.
down load the free copy of Part P document and it's perfectly clear.
as for joining Niceic etc you don't have to but why not cos its cheaper than paying the LBA to notify your work.
no...
yes...
As to the first 'no'.. I believe you are wrong Glen. Matthew says he has 'been told yes and no so many times my head is in a spin' which shows that many people are unsure about whether you 'have to be part P, have to belong to a scheme' etc etc. Also there are quite a few similar posts, so 'No' I dont think it is very clear.
Was going to write a bit more but called out!!
its clear to me...
cant understand what all the confusion is about...
its clear to me...
I know you like calling a spade a spade Glen but I think you are way off here ;)
I agree with happyhippy - there are probably thousands of very experienced electricians out there that have never worked or had any training in domestic. Doesn't make them any less of an electrician if they have to ask what the rules are relating to part P.....
I am also confused by the other bit of your response to HH.
HH said
My understanding is that if you want to undertake any work that is notifiable (i.e adding a new circuit to CU, replacing a CU or any work in a special location) thenyou do HAVE to belong to one of the schemes OR be competent to carry out the work and pay the £180 to building authorities to check the work.
So to do notifiable work you need to be competent- define that as you will ;)
Then you need to notify it to LABC, either as a scheme member or by paying a fee up front.
What bit of that is wrong?
Just trying to make it clear for the op......
Could you please clarify what "training in domestic" means.
A spark is a spark regardless the same principles apply to all installation regardless of where the job is.
I disagree. The principles may well be the the same but the regulations and practice can be very different depending on what you working on. That is what I mean - for example in domestics there are regulations (such as Part P!) that can be ignored when doing industrial or comercial work.
So I guess by "training in domestic" I mean learning the areas of the building regulations that relate specifically to domestic. It could also cover best practice where it differs from comercial and industrial.
