Fairly unusual for blowing lamp to take out a 3036 so I would go with getting it looked at
Not really. i have experienced it in the house I'm in now.
@the OP... I know that as a newly training spark, the old stuff takes some getting used to, but it will do you good to become familiar with rewireables and fuse wire, so go get some appropriately sized wire, change it, and the bulb - yes BULB- you don't buy a light lamp do you? and get it changed, then pat yourself on the back for having climbed one step further up the learning ladder.
oh aye?...for terminology such as this?
Evening, firstly, im a pretty new apprentice, not going to attempt anything myself, but wondering what the hell might have just happened...
Nackered today, just came up to bed and switched on the light in the room, and BOOM. Loud pop and a nice bright purple flash from the light fitting... Ive a fuseboard in the house..yes...rewireables..they need to get ripped out... but the lighting fuse blew and ive no lights tonight. I would change the fuse, not something I have a problem doing, but im afraid of a short or something in the fitting and causing more sparks etc...
The fitting is a metal 3 spot light GU10 fitting that you can move and point what way you please. Ive the standard GU10 bulbs fitted. I noticed one seemed bright earlier when it was working, and I had no problems this morning. Cant look now as not willing to do so + its dark but confused why It might have happened... ive never had a blown bulb take out a fuse on me before.
All comments, helpful and harsh welcome ;-)
A little lesson in chemistry for you. You will be able to impress the ladies with your newfound knowledge :drool5: ...lol. A spark is electricity flowing through a gas and in doing so it has to rip the electrons off the gas. Those electrons then recombine with the atoms at which point they release lots of energy in the form of light. Different gases release different colours of light. Since the air in our atmosphere is mostly made up of nitrogen what your essentially seeing is not electricity but nitrogen glowing. However, a purple spark would suggest there was also a high level of Argon which is usually produced as a side product of radioactive decay. Which then raises the question: What the hell is decaying in your bedroom...lol
Wicked chat up line!
Can I use that? :-)
were never called lamps, only bulbs, until the advent of florry tubes, when some bright sod said " hey, these aren't bulb shaped, let's call them lamps". how would the joke sound if it read "how many psychiatrists would it tale to change a light lamp?"
