S
Stroppy
I've put a cardboard box over it, that should do!
Does that mean you didn't install an earth pit then?? If so what have you used to protect the cable connection to the rod??
No I didn't. The rod has a green box on it, and the cable is protected from damage by going through a length of flexible conduit into the house.Does that mean you didn't install an earth pit then?? If so what have you used to protect the cable connection to the rod??
what i cant understand as well is what a bit of copex is supposed to do against Mr. Fothergills spade?...What do you mean by a green box?? It's the actual cable to rod connection that needs ''long time'' protection.
I think we should open up the depth in garden thread again, I never felt we drew a line under it anywaywhat i cant understand as well is what a bit of copex is supposed to do against Mr. Fothergills spade?...
I wonder what they thought they were going to achieve by doing that?? lol!! The chemicals in the cement will probably be doing more harm than good to the connection!! lol!!
One of these green boxes that say "safety electrical connection" on. Bearing in mind the distance from the rod to the wall is less than 30cm the probability of damage is minimal.What do you mean by a green box?? It's the actual cable to rod connection that needs ''long time'' protection.
