E
Engineer54
but you wouldn`t though....would you...lol
Oh yes he would, cause the BGB told him so!! lol!!
you dont take the risk though strops.....
a properly sited, well installed TT system would not be unduely affected either way....
we always take the worst case scenareo strops when dealing with electrical installations.....
So considering my Ra was 125 in the first place I should have left it then, but I didn't!You are permitted to have a Ze for a TT supply up to 200 ohms - Above 200 ohms it may become unstable..
Bearing in mind with my service bonding connected I am getting 0.45 I'm satisfied I have a good EFL path.
so lets say you got just within 200....Yes you have missed something. It is an existing TT system of which I was upgrading the rod as it was giving 125 ohms, which technically satisfies the BGB, but it reality is a bit rubbish. The 0.45 is the resistance of my bonded pipework (underground gas and water pipes) when tested without the earth stake (new or old) connected, not the service head. As I know we shouldn't rely on bonding for our earth path I set about replacing the rod, which got it down to 44.
I was joking about peeling back the plastic off my incoming cable and wrapping the earth wire around the armour.
would you be satisfied with this...?
as far as BS7671 is concerned its good....
but its time to ask yourself what you truely believe....
thanks Daz...He's already said that he had 125 ohms so he decided to improve it. So no, he wouldn't be happy with 200 ohms. Daz
i`m just being picky...Well, if he's not happy with 125 ohms, then why would he be happy with 'just under 200 ohms'? I don't get where you're going with this? Daz
At least one person can see why I'm getting exasperated! I wasn't happy with 125, so upgraded the rod, and they ignore that and still sayWell, if he's not happy with 125 ohms, then why would he be happy with 'just under 200 ohms'? I don't get where you're going with this? Daz
this isn`t in the regs strops....At least one person can see why I'm getting exasperated! I wasn't happy with 125, so upgraded the rod, and they ignore that and still say
"would you be happy with it?"
"Oh yes he would, cause the BGB told him so!! lol!!"
And when the existing rod is in a rubble-free position they still want me to move it a metre down the garden to avoid non-existent rubble. Now who's blindly following the regs?
surely that green box doesn't comply with current regs. it should be green/yellow, with neither colour taking over 70% of the surface.
