Discuss Novice needing help with breaker/ furnace in the UK Electrical Forum area at ElectriciansForums.net
Mamamary
New home owner here. I know zero about furnaces and breaker boxes. I need to shut off the power to my gas furnace but there is no switch located anywhere near the furnace (above, beside or on) and the breaker is not labeled. Would the furnace be the one with the biggest switch, on the far right on it’s own? Very much on my own here
not possible to determine which breaker through internet. i suggest you get a local qualified electrician who will have the right equipment to locate which breaker isolates the furnace, and perhaps fit you a form of local isolation. bear in mind, i'm in UK and don't know the regulations in Canada.
Hi,or bonjour?
If it is gas,it may only require a light electrical input,and be linked off another circuit.
Ensuring you have everything switched off,at the control switches,you could switch of each breaker,one at a time,at your fuse board,to find what powers the furnace (boiler?)
Is this a new home,or just new to you?
[automerge]1572943155[/automerge]
Does No.1 say stove?
Mamamary if you have gas the no it’s not going to be the biggest breaker I would say it’s a 20 amp double pole breaker. After all you need power for is to run the fan and energize the gas solenoid and for the low voltage controls, it’s not going to draw that much current
Reply to Novice needing help with breaker/ furnace in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Hello, Newbie to this forum here in the U.S. My 1970's house has a main/sole electric panel with a dedicated 20A circuit breaker for the furnace...
Hello all, new here. In the near furture i want to install an electric tankless water heater. I would do gas but i only have electric in my home...
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
