This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
the pict
Mentor
Never knew these existed, are they legite, its like a bloody great urn with a alluminium lid should I advise getting shot of it
Pict
a bit more info. and a pic. is it a tea urn, steam engine, or a c/h boiler.
No it is a copper hot water tank with a pukka immerser in a bedroom cupboard it even has a big red plastic quilted blanket recently fitted, inside it has a float valve like a cistern, at first I thought is was a cold water header tank till I saw the immerser
Pict
it's not one of them fancy tanks with a header tank stuck on top, is it?
something like this?
Pict
"Hello the pict",
As snowhead correctly identified this will be a Fortic Cylinder / `Combination Cylinder`.
As He stated these are primarily used in Flats etc. where there is nowhere to install a Cold Water Storage Tank to supply the Cylinder - it has its own small Tank on top of the Hot Water Cylinder.
Here is a Diagram of how an Indirect one [Usually Heated by a Boiler] is constructed - there are also the Direct type which just have an Immersion Heater.
Here is a link to a webpage where this Diagram can be viewed - in case as has happened to Me previously on here this Diagram disappears from this message:
fortic cylinder - Google Search
Regards,
Chris
Cheers Chris that looks like it right enough, I am tying up with the plumber today to discuss an alternative, But looking at it with a little fettling this would make a fine still
Pict
