Discuss Oval Grommets for 15mm boxes in the UK Electrical Forum area at ElectriciansForums.net
Don't the 20mm ones fit them, if you squish them? i.e. 16mm oval radius = 20mm circle radius
Alternatively, if the KOs are not really knock-outs, but with a sort of bent-over flange, which is smooth, I wouldn't bother putting a grommet on them, as there's no sharp edge
As #3, most have rolled edges. No need for grommit. And if you do use a grommit, the hole becomes too small to fit many cables in.
Only top entries are rolled, though. There are other, various knockouts too.
Remember...... for donkeys years they came with a slimline grommet?
I use a Wallace, I know it's late and I'm tired....................and my mind is working in a very strange way.
I always thought Grommet needed to go on a diet
Reply to Oval Grommets for 15mm boxes in the UK Electrical Forum area at ElectriciansForums.net
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I've just started using the NAPIT forms for EIC's and EICR's and they are a bit cumbersome to be fair. Does anyone know which observation is for a...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard...
