Discuss Overloads? in the Electrical Forum area at ElectriciansForums.net
Yes, standard motor overloads, I can guess if this is to regulations that the coil voltage is DC and highly likely to be 24v DC... Lucien will know where I'm coming from.
If this is to regulation then the wrong wire colors have been used for 24V DC
Panels etc are not really my game but I thought 24V was white?
DC control when working to En60204 should be dark blue.
how do you know what a vsd is set at?
Do vsd's take in single phase and spit out 3ph
Depends on the brand tbh, some need a plug in programmer/display and others just need a parameter search to look it up. Why the random question, I cannot see a VSD in the pic's?how do you know what a vsd is set at?
I would suggest the builder of this panel is clued up about how to design controls and circuits but is lacking in knowledge of the BS60204 as they have cherry picked certain reg's and totally ignored others, also I would suggest a PLC would have simplified this set-up greatly.
Vsds can be single phase in or 3 phase in. All output 3 phase. They output the same voltage as they are inputted (no doubt there will be exceptions but none that I have seen) ie 230v in single phase = 230v 3 phase out.
400v 3 phase in = 400v 3 phase out.
Reply to Overloads? in the Electrical Forum area at ElectriciansForums.net
