Don't think there's any 100V line stuff here - seems like low impedance stuff from the OP, although could be wrong. If it is then the fault finding, as stated before, is simple continuity of wiring and resistance of speaker testing. As long as you can work out series/parallel impedances then job's a good 'un.
Ensure the total impedance of the speaker network is something around the recommended impedance for the amplifier and all should be OK.
PS, that's a nice big valve amp at 75W Lucien - KT88 tubes? Daz
