Discuss Phases in dado trunking. in the Commercial Electrical Advice area at ElectriciansForums.net
Hi all and thanks in advance for any replies.
I was wondering if whether when having more than one phase inside a dado trunking are you required to mark up the trunking with a 400v marker/label like you would at a multi gang light switch??
Cheers
Cheers
No requirement.
According to bs 7671 a warning label is only required when the line to earth voltage exceeds 230 volts ac. You would only have 400volts between phases.
I still however label a 3phase db with a 400v sticker/warning notice just the way I was taught and I think it's good practice
Cheers
I don't know if it's a requirement (ignore that cheers lee:D) but I certainly would, not a big sticker but maybe the smaller etched ones placed on the lid, just in case someone who isn't competent decides to have go at chucking a couple of extra sockets in.
Reply to Phases in dado trunking. in the Commercial Electrical Advice area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
I'd appreciate a quick sanity check, thanks in advance: New circuit for a 3 phase cooker, in a community centre (run by a charity). Total load...
Hi All, I have recently purchased a motor soft starter from aliexpress for a 3 phase motor Before connecting load I measured the input and...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
