S
Sav
Hi again guys,
Just a quick question.
I have just wired an office and store room built in the back of a 44 metre garden.
It is brick built and split into office and store room.
I have installed a 17th edition RCD split load board 10 ways ( only 5 circuits being used ).
A 16mm armoured cable has been run from inside the house ( 25mm tails into henley blocks ).
My question is can i get away with using a Wylex 60amp isolator (25mm tails in supply side,16mm armoured in load side), to isolate the office power, or do i need to put in an RCD isolator ??? The consumer unit in the office has a 100amp main breaker ( which I am replacing for a 60amp one).
The armoured comes out of the side of the house, along the bottom side kitchen ( about 3 metres), the buried in the ground ).
Sorry to be so specific, but any advise / help would be great.
Thanks again guys,
Sav
Thanks again guys,
Sav
