Discuss Please put my mind at rest in the UK Electrical Forum area at ElectriciansForums.net
H
Hottub
hi guys I have had an electrician come and put some wiring in ready for a hot tub delivery.
I passed on a electrical document sent to me by the hot tub company which had 6mm on it.
He has run a armoured 2.5mm 3 core cable from the main board and a dedicated 32amp mcb to an external rotary switch ( about 3 metres away ) also 32amp. From the switch he has run the same 2.5m 3 core around to where the hot tub will be ready to be connected ( no more than 4m away ).
He says its more than enough but as I've seen 6mm on the wiring diagram I'm worried.
So shall I stop worrying? Or demand he use 6mm? Or find a different sparky?
Thank you for your time.
it may well be that 2.5mm cable is adequate for the load, but the rating of the MCB should be below the design current, unless he's working on the principal that the tub is a fixed load and thus can dispense with overload protection. tin hat ready.
Seems very odd that he knows the rating of the hot tub then either totally miscalculates or is not competent.
all boils down to this:
1. what is the load current of the hot tub? get that from rating plate.
2. from the above, what size cable is required? from BS7671.
3. from the size of the cable, what rating should the OCPD be? Ib<In<Iz.
simpleesss.
Reply to Please put my mind at rest in the UK Electrical Forum area at ElectriciansForums.net
Upgrading the Hot Tub to a Swim Spa, current power for the hot tub is 6mm 3x core swa to a 40amp mcb and 40amp rotary isolator. Cable is clipped...
The ongoing kitchen refit..... I have chased and fitted 10mm T&E from the cooker outlet to the isolator switch and up into the loft. I have 4...
Hi, looking for some advice, 6mm swa allready installed to a hot tub Client now wants additions and my calcs say the original swa is allready too...
Good morning. Needed some advice please. I am getting an AC condenser unit installed on an outer bedroom wall but only after some internal...
Hi Guys So I've never installed a hot tub supply before so take it easy on me. I've spent a bit of time researching it myself and its a minefield...
