davidcaulfield
Just doing a CU change and there's no continuity on the rig main which does down stairs upstairs and kitchen all on one circuit. The plumber had recently added underfloor heating to this circuit in a bathroom.
I asked him for his results and he went mental at me saying he didn't need a certificate because it was already there.
All I wanted was his continuity results to see if he cause the fault or it was already there
You're gonna have one happy client unless you can find it somewhere. It could be that the earths have popped out somewhere. As E54 has said, check the FCU where the plumber has put his underfloor heating and see if the earths are connected to the terminal.
It'll be either simple or a massive effort.
Just to let you know I have reported you to the Mods about the discraceful language regarding the name of the thread here :earmuffs:
Reactions: 3 people
I can imagine the householders facial expression when you tell him that you need to downrate the circuit to 20 amp lol
Then you give the explanation why and the client thinks you don't know what you're talking about and try's to argue.
Grit teeth time shortly follows.
is this plumber qualified to install ufh, and has he notified it?
A plumber doing a continuity check on a FRC, don't make me laugh. I doubt he would have done the tests on the actual mat!
Reactions: 1 person
He hasn't tested the mat! The continuity is lost on live neutral and cpc!!! I can't put he whole house on a 20amp. It might be a fault from years ago but he should have tested it before adding more load! He hasn't certificated or notified and he said well I can get an electrician to come do a certificate quickly and there won't be a problem lol
Well...
Well then you don't have a ring.
Why? It's not a ring, so you're going to have to unless its 4mm which i doubt.
Reactions: 1 person
Thats a non spark for you. How long have you been in the business?
either
1. it was never a ring. 2. someone has split it doing DIY. 3. plumber has split it coz. he ain't got a clue if it isn't poo (poetry as well today)
Reactions: 5 people
if the ring cannot be reinstated, you could convert to 2 x 20A radials.
Reactions: 1 person
2 radials on 2 20 amp breakers, but I would definately get to the bottom of it and inspect the Bummers wiring LOL, thats worth a laugh for sure.
Reactions: 1 person
plumbers
davidcaulfield,
Silly Sausage,
