Discuss Pool wiring in the Australia area at ElectriciansForums.net
Y
YTSOxford
Right, I am preparing mytself for some stick with this post. I am part P and registered...so domestic is my thing, however I have a job at the moment of which part of the contract is to wire in a pool. I have done many a hot tub, but this is my first pool, so was wondering whether you guys could point me in the right direction.
I was thinking of putting the pool on its own CU, since the main house is already submained from the meter box, and with the pool heater I am sure the board would be overloaded.
The problem now is, the outhouse was meant to have a covered area for the pumps etc, but now it isn't, so theis CU would be exposed! MK do a IP65 cu but I still aren't sure whether this is a good idea? What do y'all usually do?
your thoughts appriciated as always!
I suggest, before crashing ahead with anything, is speak to the supplier or installer of the pool and find out EXACTLY what is required.
If you do have to put a small CU outside then a suitably rated IP enclosure would be fine, even just mounted under a sloping lid with a bit of shed felt.
Thanks fo your replies guys. I have spoken to the builder again and apparently the heater and pump will be sheltered, so I guess the could go in there. As far as requirements, so far all I know is its going to have a 9kw pool heater.
I suggest you mount your controls inside a mini pillar,ie one of those green boxes that they use for street lights.
Reply to Pool wiring in the Australia area at ElectriciansForums.net
Not sure I'm posting in the right place but: We had a pool built. There are 5 LED waterfalls installed. The LED strips can toggle between 5...
Just had my design project handed back to me from my last block and I got everything right apart from one question Q9 I would take a photo but...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
In 2019, I had a lot of renovation work done including a full re-wire of our three storey house. Before the re-wire was finished, we parted...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
