Discuss power in cpacitor... in the Australia area at ElectriciansForums.net
Hey.
The charge stored by a capacitor is proportional to the voltage applied to it and this is said to be the capacitance of the capacitor.
This is the formula you need - C=Q/V
Where C = cpacitance measured in Farads
Q = total charge stored in coulombs
V = voltage
So 1 Farad is the capacitance which will accumulate a charge of 1 Coulomb when connected to a supply of 1 Volt.
Obviously you can transpose this formula to find any of the three values.
Hope this helps.
Cheers:D
Ok sir thats i know, but my question is, is it take power(KW)? while it connected to load for improving power factor..
(Otherwise it supplies reactive power [KVAr] only with out taking real power[kw])
Ok I see what your asking now.
A Power Factor Correction Capacitor (PFCC) supplies reactive power (KVAr) to a system in order to correct a poor power factor without taking any active power (KW) out of it. Otherwise it would be continually working against itself to correct a problem that it itself was creating.
Hope this helps.
Cheers.
A capacitor connected across an AC supply will consume power because it takes current from the supply. You can calculate the current from the impedance of the capacitor at 50Hz (1/2*pi*f*C) then calculate the power consumption.
Reply to power in cpacitor... in the Australia area at ElectriciansForums.net
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
I have a lighting circuit cable (1mm) powering a telescope (12 volts) in an observatory total draw 84 watts drawn from a transformer. There is a 6...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
