W
wildbean
Been asked to put some power into a shed. The house is a new build and has been signed off. There is an outside socket not 5m away from the shed.......can i spur off that socket into the shed on to a 30mA rcd and put a 13amp socket and 5amp light in the shed without needing a cert.
Im still on the 16th ED due to some time out and these new regs are driving me mad. Many thanks.
not any more unless i'm mistaken. @ OP. your outside socket will already be RCD protected. easiest way would be to plug in a 4 way extension lead, add a plug-in light.
Thanks for reply.....Can i not even plug a 4mm flex with 13amp plug plugged into the outside socket (protect the flex with metal conduit) to feed the shed as this would only act as a extension lead like plugging in a mower. Thanks.
Why 4mm? Put it in conduit, it's still only an extension lead. Is the customer going to be happy you have basically done something they could easily have done themselves!
