P
peterm
Hi guys (and gals)
I got called out to have a look at a problem someone was having with the PA in their pub. Basically when you turn the coffee machine on there is a loud 'crack' over the PA. I couldn't pull the coffee machine out to check but I'm guessing it's about 5-7kw. Usually with a heavy load or an inductive load such as a bank of lights or a load of fridges in such premises you would have them on a different phase as a sound system (am I right?)
Well the pub only has a single phase supply, so obviously you can't have the sound system on a separate supply from this coffee machine. I'm wondering where to go with this next... Can I fit some sort of suppression unit on the PA? Maybe across the terminals in the coffee machine?
Thanks, Peter.
You could fit a filter to the coffee machine, they fit them to the inside of washing machines across the incomming live and nuetral
Another possibility could be that the amplifier is picking up the arc of the coffee machines switch as the contacts make.
If the amplifyer is close to the coffee machine it might be a good idea to move it, and/or any cables routed in close proximity.
