C
curious1
Hi,
First post here, so please be easy on me... and apologies if I'm posting in the wrong place!....
Please find photographs enclosed which show a new electrical installation our landlord provided in our kitchen area.
http://dl.getdropbox.com/u/1620039/DSC_7329.JPG
http://dl.getdropbox.com/u/1620039/DSC_7330.JPG
I would be grateful if you could provide a confirmation that my assessment of the wiring and plumbing is reasonable as I am in the process of lodging a complaint with my landlord.
1. Power supply to Water heater (located on floor) is unsafe : connects to a consumer extension lead and is routed beneath water supply and drainage.
2. Water heater is incorrectly installed : pressure valve (overflow) is not plumbed into any drainage, so any overflow results in water pooling(visible in photos) on kitchen floor increasing risk of electrocution due to badly routed cables.
3. Further risk due to leaking connection between P-trap and main stack causing water pooling on kitchen floor and under extension cord socket.
4. Earthing missing from sink ?
Am I being unreasonable?
I'd love to hear some opinions from the professionals here.
Thanks in advance
c.
What is the capacity of the water heater?
Unsure of the existing cable size from the pictiure,would need to know the capacity of the boiler and the KW rating to offer an opinion on it
The extension lead looks more like a corded drill lead adaption than a standard extension lead
A switched fused spur in an accessable postion fed by a suitable size cable,with heat resistant flex into the boiler
Either off a dedicated circuit or spurred off a local ring main,depending on the load of the boiler and the water capacity which it may require
More info required for a response
No competence as regards the plumbing,sorry
Thanks for the fast reply.
Not sure what the capacity is, but here is the manual for the boiler. http://www.bosch-store.us/images_templ/ariston-gl-manual.pdf
Capacity : 2.75 - 5 gallons
Power at 120 Vac = 1500W
Amperage = 12.5A
Can't say for sure about the cable size, but from the photo, if you zoom in, you can see that the grey cable is about the full width of the plug hole for cabling; so about 8-10mm wide?
Extension cable runs behind the fridge to a double socket (powering fridge) which is a spurr from another socket 8-10mm cable (powering 800W microwave, toaster and kettle). Not sure what circuit that socket is on...
I'm pretty sure the cable itself is over-specced for the loading from the boiler, but I'm more concerned about the manner of fitting, ie the routing of the cable under the pipes and water supplies (which have both suffered leaks onto the cable). If the plug was to fall on the floor and the water was to continue to leak, the kitchen floor is almost guaranteed to become "live" ....
Thanks again.
The plumbing is a disgrace in general, however the heater does not pull 12.5Amps
1500w load @ 230v = 6.52 Amps
Its hard to pass judgement on it by means of pics, you could always try asking your landlord for a electrical Periodic Inspection Report (PIR)
That would involve a reputable spark checking the installation and putting his name too it
Would sort it one way or another
Haha, yea it is a joke. Thankfully we're outta here soon.... but in the meantime I'd rather not feel like I'm in an episode of "Casualty" every time I go to make a cup of tea.
Yep, once the landlord fixes it up, I'll get the PIR or have HSE come and have a look. No doubt he'll throw more money after bad and get the same old jokers back in to fix it up.... hopefully the HSE will condemn the work.
Thanks again for your replies... much appreciated!
Sorry but the HSE wont touch it as its a resi dwelling, you could demand to see a certificate for the works and then refer it to building control as its a special location being a kitchen
No its not resi, its a kitchen in my office...
// edit .... Sorry I should have mentioned that in my original post!
At the very least that socket should be done in mechanically protected fixed wiring to an IPX4 rated socket and from a circuit with 30mA RCD protection as it's a location with increased risk of electric shock. That's the way I've always done it under sinks, even if they are in kitchens not bathrooms.
For the life of me, I can't remember where this is stated, but I've always thought that any permanently fixed equipment over 2.2kW should be on own circuit.
You might be thinking of any cooking appliance over 2kW should have its own radial from the CU.
Why I asked for the water capacity was that in the on site guide water heaters over 15 litres capacity should be supplied by their own seperate circuit App 8.5
It looks very poorly done but by being on a plug its technically classed as a portable appliance ( different term probably in the purple pat book)
All the extension leads may lead to some overloading
No requirement to bond the sink
Thanks again for your advice(s) ...
For your entertainment, I identified the source of the leak, the plumber had actually drilled a hole in the back of the sink soil-pipe and inserted the copper overflow pipe into the hole, and sealed with silicon ( I kid you not). Some movement of the unit has obviously caused the pipe to pop out and now the kitchen floor is being flooded.
The landlord had the plumber round who accused us of vandalising the unit by moving it! ... and the landlord is siding with the plumber not seeing that the installation is patently substandard.
Is it wise(ie safe/hiegenic) to plumb a water heater directly into a sink soilpipe after the p-trap ?
Since when is silicone a suitable fixing method between two pipes? !
Why wasn't the builer fixed to the wall to reduce the chance of the silicone seal being damaged through movement?
I love these situations... so much fun!
