Does anyone know of a suitable alternative to a Proteus MCCB, as they seem to be difficult to get hold off, and alot more expensive then a different make, I'm after a 63amp if anyone has got any ideas.
Eaton ones i think are made by the same people , thats what they try to give me in cef if they dont have proteus , but arnt they all din mounts anyway ?
Eaton ones i think are made by the same people , thats what they try to give me in cef if they dont have proteus , but arnt that all din mounts anyway ?
Whilst they are all din mounted, the protrusion through the front of the CU cover is slightly different (often) between manufacturers, so not all makes fit all CU's.
Do they make MCCBs for CU mounting?? I can't for the life of me, remembering ever seeing an MCCB in a CU enclosure. Seen them in commercial type DB's....
Its the Proteus f31 range, bit on the costly side, might have to go down the route of separate enclosure and upgrade the tails from existing board to new enclosure.
