Discuss pure Nickel cable grouping factor in the UK Electrical Forum area at ElectriciansForums.net
Where can I find specific information on pure Nickel glass woven insulated Conductors for Cable grouping factors? I want to know the derating for 60cables @1.5mm in conduit 3 Phase
Interesting question. What current capacity are you assuming in the first place?
The de-rating factor is probably much the same as for normal conductors, in the sense that if you have a specific temperature rise allowed, then bunching lots of cables together has more heat added compared to the ability of the bunch to dissipate heat.
But equally some cables like that are rated to 400C (or even as high as 700C in some case) which is probably beyond what the conduit could ever survive!
Sounds like one big conduit, does that!
A bit more detail?
A bit more detail?
1.5" conduit will accommodate 61 stranded pvc 1.5mm conductors according to the OSG, though with the extra insulation thickness it is likely you would have to go up to 2" to avoid overfilling the conduit.
the conduit is 50mm, the cable is 1.5mm2, but i cant find anywhere with Cable correction factors for Nickel cable? where can i find this? i want to derate the cable suitably, so i get my CSA correct for the current being pulled, thanks
Be difficult with 32m.....2'' conduit....is it existing?
edit. See it is. Hope it's not too long a run...and use gloves.;)
Reply to pure Nickel cable grouping factor in the UK Electrical Forum area at ElectriciansForums.net
Hi All I would appreciate some help with a few questions here regarding cables sizing, I'm using the latest 18th edition, amendment 2. Q1...
I have a fuseboard change I need to do soon I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD My only concern is how I should run the pyro cables in...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
