When they formed the jib they gave several thousand blokes sparks tickets under the "Grandad rule".These blokes had never set foot in college but had been sparking for 20 or 30 years.I have worked with a lot of old boys like that.They were some of the best sparks i have ever met.Are you trying to say someone who has done a fasttrack course or a electrical trainee is more competant then them just because they have sat a few exams?
To the OP if you want to get a jib card you will need to do the c+g 2356 plus the NVQ
If you just want certs for an employer the 2356 will be enough
In the last 25 years I have done mostly rewire s on house's
Micc, fire alarms system, conduit, trunking, tray work, a lot of testing, pat testing and very knowledgeable on thr regs
I will be starting a housing association contract soon and need to be 17 edition
If the op is time served then to satisfy some employers or even a scheme then 17th edition and 2391/2392 should be ok and if he needs a jib card then do the h&s test,time served sparks worth there weight in gold these days(or should be).
In the old days sparkies stuck to a single very specific scope of work, I'm guessing this was because f the unionisation in those days. You got a refrigeration sparky who worked on nothing but HVACR controls and you got a commercial EL&P sparky who worked only on commercial electric light and power. These guys would work 50 years on almost exactly the same type of installations without diversifying. In those days it would have been a sensible move to just give them a 'Grandad' ticket.
Problem nowadays is sparkies can be working on standard domestic one week and installing commercial control panels the next so more than ever they actually need a structured broad-based education that can be applied to whatever environment they find themselves in. Alas that education system seems to be going the other direction. But back to the OP, you could install containment and cabling all your life without qualifications and only with on the job experience but what do you do the when you're expected to step outside of your comfort zone without a structured education behind you?
http://electrical.----------/wiring-matters/44/what-is-an-electrician.cfm?type=pdf
Although I agree with many points in the article, I can't help but feel that it was written with the intention of glorifying a certain outfit and not for clarification. The author of the article (who is also the CEO of a certain outfit) may as well have written "if you don't do it our way, your doing it wrong" which we all know is not accurate
I think that hits the nail on the head.
I actually think the emphasis on qualifications is very dangerous. How often do we here "I am a qualified electrician" but soon realise the guy isn't really ready to be let loose on his own. On the other hand, so what if someone doesn't have the latest 17th edition qualification if he has 25 years experience and a sound understanding of the principles (plus had a read of the BGB)?
I've always found that it is only those without any, or minimal qualifications that come out with that sort of crap!!
A ''Core qualification'' is an absolute must for any working electrician, ...end of!!
Not in my time it wasn't. When you came out of an indentured apprentice system you had the overall knowledge to work in ANY sector of the electrical industry. Depending on the complexity of the industrial sector, an apprentice just out of his time may have needed some extra training on the plant he was expected to maintain/install. But other than that he could quite happily slot into any sector of the industry. Specialisation in any specifics generally came later as experience was gained....
What do you mean by ''glorifying'' a certain outfit?? Give credit where it's due!! For all it's faults, the JIB are still the only organisation that is a solid block to any fast track/back door merchant that is under the delusion of being an electrician, and long may they continue to do so!!
Totally agree, I'd take experience over quals any day of the week!
