This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
cliffed
Not having much help of mech guys on site,concerning heating system.Bascically they have 2 Quinta boilers,the problem is connecting the control cables of these boilers,using external controlling,ie:valves etc.The output of these connections at boiler are 24 volts,& these boilers need to communicate to each other,so they cannot be piggy back connected.Ive told the mech guys,a sequence controller will be required,any ideas.cheers
As far as I know, you are right that the boilers can't communicate with each other. You will need a sequencer to control the two boilers.
Depending on the installation, it may be better to install a control panel with a small BMS. You could then control each boiler with a O-10V signal so you can modulate the output.
http://www.kanmor.com/multistaging/264e.html
if you contact http://www.kanmor.com/aboutkanmor.html radiant control they will produce you a wiring diagram (they did when I had two Mitsubishi ASHP connected through two FTC's back to a kanmor controller).
