G
just bought pub liability insurance £75.22 not bad i think
Didn't realise you needed calibration to be honest, I though provided you checked the tester with a proven measured unit and logged the results and kept a check regularly then that was adequate.
thought that but wasn't sure. could save me a couple of quid will look into how much for suitable checkboxes.
I would think you need a reliable starting reference point from which to compare values on the Calcard method. You will probably still have to provide a calibration cert from a UKAS accredited firm to show that your machine was operating within manufacturers tolerances against a range of testing values.
Point taken, Hawkmoon, - it works if you have several testers to calibrate as you would still need to get your Calibration tester calibrated.
