- Reaction score
- 165
Got a renovation to do on a ground floor flat which has been empty for a long time. The rest of the building has been renovated, pretty poorly on the electrical side! The current set up is a 16mm twin to the upper flat and a 16mm split con to the mid flat. The three phase cutout is currently in the porch of the ground floor flat so needs moving. Where do I stand on reconnecting these supplies? I'm pretty sure the cables aren't >50mm and there's no protection currently in place. Pme earth and only the top floor flat is connected through a switch fuse (100amp fuse). Cheers in advance.
