This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
I
infinity
Does anyone know the best replacement for the above model?
Its for a valliant turbomax.
British gas have been round to service the boiler recently and said they can fit a wireless thermostat that can be controlled when you are away from the home?
I cant find anything like this, has anyone uses/ heard of such a device?
Thanks Tel,
But that looks way to complicated to install as a house thermostat? It requires distribution centres etc and must cost a fortune!
I believe there is one that's just come out that you an control with your I phone or I pad which looks quite good, I would always go for wired stats if I had the choice I find wireless ones can be a pain with losing there signal and forever getting phone calls after they are fitted.
see my above post think i just found that one! Only problem for me is current stat is wireless the new one would be wired
Yes but the trouble is they use their own portal/app to use with the device. So even if we find the device it will just be a wireless stat without an app :/
^^^was not sure how to put a link up so had to type it out manually,sorry i am the forrest gump of the computer world.
right click on the address bar of the web page . click copy. then back on the forum paste.
