G
Guest111
there's always the danger someone will make one with all 3 pins connected.more importantly when you look at what it's designed to do,how the hell can just checking an earth bond be classed as proper test and inspection?what happened to unplugging an item to check plug has correct fuse and is wired correctly,may as well just do a drive by and bung a sticker on!Can't see where the danger is with this -
but agree only a d***head would pay for it.
