A few point for you to ponder.... not by any means exhaustive and in no particular order
Will the house be occupied while you are doing it?
if you need to refit floorboards/move furniture every morning and night it will have a big impact on time on the job
you will need to restore some sort of power each night, again, very time consuming. (Better to rig up some temporary power supply for the basics - heating/water/lighting/simple power radial)
if you are having to re-chase, dust sheets up and down all day (are they willing to do the cleaning every night for you, makes it cheaper for them and gives you more time on the tools)?
Basically, if the house is occupied, it's going to be a nightmare and you will need a very detailed plan of attack.
Is there a loft? Is it boarded and stacked to the gunnels with old junk? - Time consuming again
If you have to chase - what are the walls built with? for example - old rendering will probably crumble as soon as you turn on the chaser - make sure you have the services of a plasterer available, and budgeted for.
What are the requirements of the customer? - You may go and look and see a standard set up, they may want dozens of downlights/mood lighting here and there - they may not neccessarily want a like for like replacement. If it's an older property they will certainly want extra sockets in most rooms.
Future plans of the customer - are they putting in a loft conversion next year - build a snooker club in the back garden - you may need a CU with plenty of spare ways.
Consider giving the kitchen it's own ring main and giving the fridge/freezer it's own RCBO.
Existing outbuildings - the wiring in them may be as old as that in the house - easy to forget.
Don't forget to add time to remove the old cabling and accessories too - again, if the house is occupied throughout, this may also involve making safe every night.
It's a minefield buddy - I'm not trying to put you off, I'm only two years into this game myself and my first was daunting beforehand but surprisingly simple once i got into it I've only done three, two empty, which were easy and one occupied, lets say that one got emotional at times........
I'm sure this list can and will be doubled but my fingers are hurting now and i have had several beers - good luck!!!
