Rockingit
Mentor
Supporter
Have run out of stock of RJ45's and looking to get a bulk pack online, it's been a while since I've had to buy any and I'm mostly seeing packs of the 'pass-thru' type - does nobody actually use end-on snips anymore?? Also, do you need a specific crimper or can you still snip the ends off neatly in a pass-thru?
I've been using pass through connectors (when supplied) with standard RJ45 crimper and cheap electronic style, flush side cutters leave a perfectly acceptable finish.
Edit: this sort of cutter
I do Exactly the same as @nicebutdim
Those snips are great for trimming the excess cores off and for flush cutting cable ties!
Anand much cheaper than the Knipex version!! 👍
Some of those new style crimpers look excellent, but I don't crimp that many data cables and can't justify the expense - especially when my cheap crimpers do the job perfectly every time.
I looked at a Klein one the other day and thought nah mine do the job!
Tbh, I find that I will use my crimp tool for a week and then not use it for months.
If I was using it all the time I would build the cost of some snazzy ones into the job but yeah my old ones will be fine for many years yet I think!
Yeah, I think I’ll stick to how I’ve been doing them for 25 years… That said, I can see the speed advantage in not having to care about dressing the cable off!
I don't dress the cable any differently for different types of connector, other than not trimming quite so short with pass through.
Perhaps this advantage explains the high rate of issues I see with cables terminated by data 'specialists'.
these guys sell the ones you're talking about in packs of 50. RJ45 8 Position 8 Contact Plug For Cat5e Cable - https://bownetcms.co.uk/shop/structured-cabling-systems/copper-systems/plugs-and-boots/rj45-8-position-8-contact-plug-for-cat5e-cable/
Rockingit
Mentor
Supporter
Somerset
RJ45 connector types
Rockingit,
Tuesday,
