This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Hi it is for a combi boiler. I will be getting a honeywell room stat! I am just running the cable and my plumber is going to connect it all up at each end, but its all getting quite confusing which cable I should use!!! I would just ask him but he is on holiday at the mo!
Thanks for your replies! Any further advice appreciated
Honeywell roomstat will work fine.
only need 2c+cpc
I would suggest that you run a 3c+cpc if you have it, just for future proofing!
Usually the combi boiler uses 230v N/C circuit to make it operate. If you are adding a timer just break into the outward leg of the circuit with the controler.
Surprised you haven't picked up on this on Tel, i'm not saying a word, starting to get a bad name slagging of plumbers (however much they deserve it!) (dam it iv'e done it again!) Lol
RE: Min csa of cables,
To be fair I think the reg. and table I posted for HS in post #10 is aimed at distribution and feeds for final circuits, I only posted the details because I had posted them in a different thread earlier on in the day, and he asked about this reg.
I would have said in this application it would fall under control circuits, and even 0.5mm flex would be ok, so I would not get too hung up about using only 1.5mm, and it would not bother me to use 1mm at all.
After all the Current through the stat will be minimal.
I hope this clears things up a bit.
that's why i said use 3 core.m then the plumber knows that the funny bare wire is a stripping cord, not to be used as a line conductor.
I love all the comments about us heating engineers!
If it's a Honeywell t6360b then you will need a 3 core+cpc To be honest, I'd put a 3 core+cpc in anyway regardless of what you are putting in as a just-in-case measure.
A stat with an anticipator will be the best to use regardless of what heating system you have.
A stat is classed as a control and will take a load of 10A Resistive or 3A Inductive so size the cable accordingly.
