Discuss routing in the Canada area at ElectriciansForums.net
benji
if you had to run a cable(swa) and there were two routes ie.short route run it through cable compartment of switchboard(compression gland in top and one in bottom and then on to final destination).long route install cable tray from external wall (low level)to existing tray (high level) then clip cable to tray.
which would be correct i'am sure there's something in the regs about going through electrical boards but i can't find it .
yours benji
I know that you can't take a short route through a panel ,but if somebody keeps saying where does it state that you cannot do it and i can't find it and phrases like "bad practice ,relavent codes of practice" are totally alien to them its a struggle.Looked through regs. last night couldn't find anything wondering about B S standards.
Any pointers anybody
yours benji
yours benji
oh i see ,someone else wants you to do it and your looking for proof that you shouldnt ,just tell them that rumrunner says its bad practice ,that should shut them up;)
good luck
Rum been doing this for 49yrs and theres no way i will run anything through a panel that is not appertaining to the panel ,i just thought there must be something in print somewhere.
yours benji
tell them you've had enough training and experience to know its bad practice and you take pride in your work, tell them repeat business is important and if another spark laid eyes on it they wouldn't shut up about what a rough job it was, maybe compare it to something they can relate too...
i.e
sir, if you took you car into the body shop to get painted and they used a brush it would look terrible wouldn't it, although there is no regs that say they cant do it.....
i dunno i might just be rambling....
Reply to routing in the Canada area at ElectriciansForums.net
I have a job coming up where I likely need to replace old twin and earth (imperial size) feeding one, perhaps two flats in a 3 storey converted...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I have been asked to install an external socket below the meter box. The consumer unit is directly behind the meter box and I plan to put the...
4K
Hi all, I am looking to replace an existing CU (ground floor) and put it in a new position (first floor). The existing CU is on the inside of a...
