Discuss Safest way to run cable in the UK Electrical Forum area at ElectriciansForums.net
R
Ralexx
Hello everyone! I have a tricky question:what is the best and safest way to run cable? Is it better to drill joist in the ceiling or it is better to just clip it along the joist?
safest way to run cable is sit back, have a beer, let it run alone. that way you won't be prone to a heart attack, cramp, backache, leg ache, senile dementia and all those other problems that sparks suffer.
Reply to Safest way to run cable in the UK Electrical Forum area at ElectriciansForums.net
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
